Date/Time: Mon, 29 Apr 2024 00:38:16 +0000
Data fail and missing, any suggestions?
View Count: 1219
[2014-03-06 19:28:56] |
narcese - Posts: 58 |
Software version: 1102 | 2014-03-06 14:19:53 Usage end date: 2014-06-07 | 2014-03-06 14:19:53 Enabled for: Sierra Chart Historical Data Service. | 2014-03-06 14:19:53 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-06 14:19:53 Active service: TransAct | 2014-03-06 14:19:53 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-03-06 14:19:53 2014-03-06 14:19:53 Local computer clock time | 2014-03-06 14:19:53 2014-03-06 19:19:53 GMT time | 2014-03-06 14:19:53 2014-03-06 14:19:53 Time zone adjusted time | 2014-03-06 14:19:53 Program path: C:\SierraChart2\ | 2014-03-06 14:19:53 Data Files path: C:\SierraChart2\Data\ | 2014-03-06 14:19:53 OS Version Number: 6.1 | 2014-03-06 14:19:53 Checking for new symbol settings for ta | 2014-03-06 14:19:53 HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:19:53 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:19:56 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:19:56 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:20:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:28:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:28:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:13:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:00. Next Bar Date Time: 2014-02-11 11:13:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:28:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:13:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:00. Next Bar Date Time: 2014-02-11 11:13:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 12:30:00. Next Bar Date Time: 2013-12-11 08:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 12:30:00. Next Bar Date Time: 2013-12-11 08:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:15:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:15:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:15:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:15:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 11:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:57 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:19:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 12:30:00. Next Bar Date Time: 2013-12-11 10:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 12:30:00. Next Bar Date Time: 2013-12-11 10:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 10:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 10:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 10:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:20:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:00:00. Next Bar Date Time: 2014-02-13 06:00:00. Filename: C:\SierraChart2\Data\6BH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:58:00. Next Bar Date Time: 2014-02-13 06:10:00. Filename: C:\SierraChart2\Data\6BH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:55:00. Next Bar Date Time: 2014-02-13 06:10:00. Filename: C:\SierraChart2\Data\6BH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:58:00. Next Bar Date Time: 2014-02-13 06:10:00. Filename: C:\SierraChart2\Data\6BH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:45:00. Next Bar Date Time: 2014-02-13 06:00:00. Filename: C:\SierraChart2\Data\6BH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-25 16:00:00. Next Bar Date Time: 2013-11-25 08:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 00:30:00. Next Bar Date Time: 2013-12-11 00:30:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:19:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:20:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:30:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 00:30:00. Next Bar Date Time: 2013-12-11 00:30:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 16:02:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:36:00. Next Bar Date Time: 2014-02-13 16:08:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:31:00. Next Bar Date Time: 2014-02-13 16:03:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:36:00. Next Bar Date Time: 2014-02-13 16:08:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:31:00. Next Bar Date Time: 2014-02-13 16:03:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:36:00. Next Bar Date Time: 2014-02-13 16:08:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:00 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 16:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:01 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 16:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:01 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 23:00:00. Next Bar Date Time: 2014-02-13 03:00:00. Filename: C:\SierraChart2\Data\6BH4.scid | 2014-03-06 14:20:01 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:28:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:00. Next Bar Date Time: 2014-02-11 11:12:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 16:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:35:00. Next Bar Date Time: 2014-02-13 16:05:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 15:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 15:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:02 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:20:02 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:58:00. Next Bar Date Time: 2014-02-13 06:10:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:20:03 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 16:00:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:03 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:35:00. Next Bar Date Time: 2014-02-13 16:05:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:03 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:30:00. Next Bar Date Time: 2014-02-13 16:02:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:04 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-13 16:36:00. Next Bar Date Time: 2014-02-13 16:08:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:04 HD Request # 2 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: ta | 2014-03-06 14:20:05 HD Request # 2 - Download start Date-Time: 2014-03-06 14:18:26.0 | 2014-03-06 14:20:05 HD Request # 2 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 2 - Error downloading historical Intraday data for YMH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 2 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH4 | 2014-03-06 14:20:05 HD Request # 3 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: ta | 2014-03-06 14:20:05 HD Request # 3 - Download start Date-Time: 2014-03-06 14:18:26.0 | 2014-03-06 14:20:05 HD Request # 3 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 3 - Error downloading historical Intraday data for YMH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH4 | 2014-03-06 14:20:05 HD Request # 4 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: ta | 2014-03-06 14:20:05 HD Request # 4 - Download start Date-Time: 2014-03-06 14:18:26.0 | 2014-03-06 14:20:05 HD Request # 4 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 4 - Error downloading historical Intraday data for YMH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH4 | 2014-03-06 14:20:05 HD Request # 4 - Intraday download COMPLETE for YMH4 | 2014-03-06 14:20:05 HD Request # 5 - Downloading Historical Daily chart data for TICK-NYSE. Starting date: 1964-03-06. Service: statscalc | 2014-03-06 14:20:05 HD Request # 5 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 5 - Error downloading historical Daily data for TICK-NYSE. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 5 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2014-03-06 14:20:05 HD Request # 6 - Downloading Historical Daily chart data for TICK-NYSE. Starting date: 1964-03-06. Service: statscalc | 2014-03-06 14:20:05 HD Request # 6 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 6 - Error downloading historical Daily data for TICK-NYSE. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 6 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2014-03-06 14:20:05 HD Request # 7 - Downloading Historical Daily chart data for TICK-NYSE. Starting date: 1964-03-06. Service: statscalc | 2014-03-06 14:20:05 HD Request # 7 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 7 - Error downloading historical Daily data for TICK-NYSE. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 7 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2014-03-06 14:20:05 HD Request # 7 - Daily download COMPLETE for TICK-NYSE | 2014-03-06 14:20:05 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:20:05 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:20:05 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:20:05 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:20:05 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.dly | 2014-03-06 14:20:05 HD Request # 8 - Downloading Historical Daily chart data for YM#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:05 HD Request # 8 - Requesting historical Daily Continuous data for YMZ10 starting at 2014-03-04 | 2014-03-06 14:20:05 HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:05 HD Request # 8 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:05 HD Request # 8 - Error downloading historical Daily data for YM#. There was a communication error with the server. | 2014-03-06 14:20:05 HD Request # 8 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM# | 2014-03-06 14:20:05 HD Request # 8 - Daily download COMPLETE for YM# | 2014-03-06 14:20:05 HD Request # 9 - Downloading Intraday chart data for NQH4 to the file NQH4.scid. Service: ta | 2014-03-06 14:20:05 HD Request # 9 - Download start Date-Time: 2014-03-06 14:18:24.0 | 2014-03-06 14:20:05 HD Request # 9 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 9 - Error downloading historical Intraday data for NQH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 9 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH4 | 2014-03-06 14:20:05 HD Request # 10 - Downloading Intraday chart data for NQH4 to the file NQH4.scid. Service: ta | 2014-03-06 14:20:05 HD Request # 10 - Download start Date-Time: 2014-03-06 14:18:24.0 | 2014-03-06 14:20:05 HD Request # 10 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:05 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:05 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:05 HD Request # 10 - Error downloading historical Intraday data for NQH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:05 HD Request # 10 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH4 | 2014-03-06 14:20:05 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-21 16:45:00. Next Bar Date Time: 2014-02-21 16:30:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:05 HD Request # 11 - Downloading Intraday chart data for NQH4 to the file NQH4.scid. Service: ta | 2014-03-06 14:20:05 HD Request # 11 - Download start Date-Time: 2014-03-06 14:18:24.0 | 2014-03-06 14:20:06 HD Request # 11 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:06 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:06 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:06 HD Request # 11 - Error downloading historical Intraday data for NQH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:06 HD Request # 11 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH4 | 2014-03-06 14:20:06 HD Request # 11 - Intraday download COMPLETE for NQH4 | 2014-03-06 14:20:06 HD Request # 12 - Downloading Historical Daily chart data for NQ#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:06 HD Request # 12 - Requesting historical Daily Continuous data for NQZ10 starting at 2014-03-04 | 2014-03-06 14:20:06 HTTP request #2 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:06 HD Request # 12 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:06 HD Request # 12 - Error downloading historical Daily data for NQ#. There was a communication error with the server. | 2014-03-06 14:20:06 HD Request # 12 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ# | 2014-03-06 14:20:06 HD Request # 12 - Daily download COMPLETE for NQ# | 2014-03-06 14:20:06 HD Request # 13 - Downloading Intraday chart data for TFH4 to the file TFH4.scid. Service: ta | 2014-03-06 14:20:06 HD Request # 13 - Download start Date-Time: 2014-03-06 14:18:25.0 | 2014-03-06 14:20:06 HD Request # 13 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:06 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:06 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:06 HD Request # 13 - Error downloading historical Intraday data for TFH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:06 HD Request # 13 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFH4 | 2014-03-06 14:20:06 HD Request # 14 - Downloading Intraday chart data for TFH4 to the file TFH4.scid. Service: ta | 2014-03-06 14:20:06 HD Request # 14 - Download start Date-Time: 2014-03-06 14:18:25.0 | 2014-03-06 14:20:06 HD Request # 14 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:06 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:06 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:06 HD Request # 14 - Error downloading historical Intraday data for TFH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:06 HD Request # 14 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFH4 | 2014-03-06 14:20:06 HD Request # 15 - Downloading Intraday chart data for TFH4 to the file TFH4.scid. Service: ta | 2014-03-06 14:20:06 HD Request # 15 - Download start Date-Time: 2014-03-06 14:18:25.0 | 2014-03-06 14:20:06 HD Request # 15 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:06 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:06 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:06 HD Request # 15 - Error downloading historical Intraday data for TFH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:06 HD Request # 15 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFH4 | 2014-03-06 14:20:06 HD Request # 15 - Intraday download COMPLETE for TFH4 | 2014-03-06 14:20:06 HD Request # 16 - Downloading Historical Daily chart data for RJ#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:07 HD Request # 16 - Requesting historical Daily Continuous data for RJZ10 starting at 2014-03-04 | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:58:00. Next Bar Date Time: 2014-02-13 06:10:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:20:07 HTTP request #3 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:07 HD Request # 16 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:07 HD Request # 16 - Error downloading historical Daily data for RJ#. There was a communication error with the server. | 2014-03-06 14:20:07 HD Request # 16 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RJ# | 2014-03-06 14:20:07 HD Request # 16 - Daily download COMPLETE for RJ# | 2014-03-06 14:20:07 HD Request # 17 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: ta | 2014-03-06 14:20:07 HD Request # 17 - Download start Date-Time: 2014-03-06 14:18:23.0 | 2014-03-06 14:20:07 HD Request # 17 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:07 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:07 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:07 HD Request # 17 - Error downloading historical Intraday data for ESH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:07 HD Request # 17 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4 | 2014-03-06 14:20:07 HD Request # 18 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: ta | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:55:00. Next Bar Date Time: 2014-02-13 06:10:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:20:07 HD Request # 18 - Download start Date-Time: 2014-03-06 14:18:23.0 | 2014-03-06 14:20:07 HD Request # 18 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:07 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:07 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:07 HD Request # 18 - Error downloading historical Intraday data for ESH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:07 HD Request # 18 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4 | 2014-03-06 14:20:07 HD Request # 19 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: ta | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:30:00. Next Bar Date Time: 2014-02-13 05:30:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:20:07 HD Request # 19 - Download start Date-Time: 2014-03-06 14:18:23.0 | 2014-03-06 14:20:07 HD Request # 19 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:07 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:07 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:07 HD Request # 19 - Error downloading historical Intraday data for ESH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:07 HD Request # 19 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4 | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:18. Next Bar Date Time: 2014-02-11 11:10:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:00. Next Bar Date Time: 2014-02-11 11:10:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:02. Next Bar Date Time: 2014-02-11 11:10:52. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:28:14. Next Bar Date Time: 2014-02-11 11:10:52. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:22. Next Bar Date Time: 2014-02-11 11:12:14. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:24. Next Bar Date Time: 2014-02-11 11:13:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:04. Next Bar Date Time: 2014-02-11 11:13:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 HD Request # 19 - Intraday download COMPLETE for ESH4 | 2014-03-06 14:20:07 HD Request # 20 - Downloading Historical Daily chart data for ES#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:07 HD Request # 20 - Requesting historical Daily Continuous data for ESZ10 starting at 2014-03-04 | 2014-03-06 14:20:07 HTTP request #4 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:07 HD Request # 20 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:07 HD Request # 20 - Error downloading historical Daily data for ES#. There was a communication error with the server. | 2014-03-06 14:20:07 HD Request # 20 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES# | 2014-03-06 14:20:07 HD Request # 20 - Daily download COMPLETE for ES# | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:23:17. Next Bar Date Time: 2014-02-11 11:10:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:20. Next Bar Date Time: 2014-02-11 11:10:52. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:27:35. Next Bar Date Time: 2014-02-11 11:10:52. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:33:43. Next Bar Date Time: 2014-02-11 11:12:14. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:28. Next Bar Date Time: 2014-02-11 11:13:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:04. Next Bar Date Time: 2014-02-11 11:13:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:07 HD Request # 21 - Downloading Intraday chart data for 6BH4 to the file 6BH4.scid. Service: ta | 2014-03-06 14:20:07 HD Request # 21 - Download start Date-Time: 2014-03-06 14:15:26.0 | 2014-03-06 14:20:07 HD Request # 21 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:07 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:07 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:07 HD Request # 21 - Error downloading historical Intraday data for 6BH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:07 HD Request # 21 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BH4 | 2014-03-06 14:20:07 HD Request # 22 - Downloading Intraday chart data for 6BH4 to the file 6BH4.scid. Service: ta | 2014-03-06 14:20:08 HD Request # 22 - Download start Date-Time: 2014-03-06 14:15:26.0 | 2014-03-06 14:20:08 HD Request # 22 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:08 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:08 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:08 HD Request # 22 - Error downloading historical Intraday data for 6BH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:08 HD Request # 22 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BH4 | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:24:18. Next Bar Date Time: 2014-02-11 11:10:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:25:03. Next Bar Date Time: 2014-02-11 11:10:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:26:20. Next Bar Date Time: 2014-02-11 11:10:52. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:28:08. Next Bar Date Time: 2014-02-11 11:10:52. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:34:20. Next Bar Date Time: 2014-02-11 11:12:14. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:28. Next Bar Date Time: 2014-02-11 11:13:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:36:04. Next Bar Date Time: 2014-02-11 11:13:17. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:20:08 HD Request # 23 - Downloading Intraday chart data for 6BH4 to the file 6BH4.scid. Service: ta | 2014-03-06 14:20:08 HD Request # 23 - Download start Date-Time: 2014-03-06 14:15:26.0 | 2014-03-06 14:20:08 HD Request # 23 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:08 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:08 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:08 HD Request # 23 - Error downloading historical Intraday data for 6BH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:08 HD Request # 23 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BH4 | 2014-03-06 14:20:08 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-14 00:45:00. Next Bar Date Time: 2014-02-13 06:00:00. Filename: C:\SierraChart2\Data\ESH4.scid | 2014-03-06 14:20:08 HD Request # 23 - Intraday download COMPLETE for 6BH4 | 2014-03-06 14:20:08 HD Request # 24 - Downloading Historical Daily chart data for B6#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:08 HD Request # 24 - Requesting historical Daily Continuous data for B6Z10 starting at 2014-03-04 | 2014-03-06 14:20:08 HTTP request #5 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:08 HD Request # 24 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:08 HD Request # 24 - Error downloading historical Daily data for B6#. There was a communication error with the server. | 2014-03-06 14:20:08 HD Request # 24 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for B6# | 2014-03-06 14:20:08 HD Request # 24 - Daily download COMPLETE for B6# | 2014-03-06 14:20:08 HD Request # 25 - Downloading Historical Daily chart data for GC#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:08 HD Request # 25 - Requesting historical Daily Continuous data for GCZ10 starting at 2014-03-04 | 2014-03-06 14:20:08 HTTP request #6 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:08 HD Request # 25 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:08 HD Request # 25 - Error downloading historical Daily data for GC#. There was a communication error with the server. | 2014-03-06 14:20:08 HD Request # 25 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GC# | 2014-03-06 14:20:08 HD Request # 25 - Daily download COMPLETE for GC# | 2014-03-06 14:20:08 HD Request # 26 - Downloading Intraday chart data for 6EH4 to the file 6EH4.scid. Service: ta | 2014-03-06 14:20:08 HD Request # 26 - Download start Date-Time: 2014-03-06 14:15:42.0 | 2014-03-06 14:20:08 HD Request # 26 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:08 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:08 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 26 - Error downloading historical Intraday data for 6EH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 26 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH4 | 2014-03-06 14:20:09 HD Request # 27 - Downloading Intraday chart data for 6EH4 to the file 6EH4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 27 - Download start Date-Time: 2014-03-06 14:15:42.0 | 2014-03-06 14:20:09 HD Request # 27 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:09 HD Request # 28 - Downloading Historical Daily chart data for E6#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:09 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 28 - Requesting historical Daily Continuous data for E6Z10 starting at 2014-03-04 | 2014-03-06 14:20:09 HD Request # 27 - Error downloading historical Intraday data for 6EH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 27 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH4 | 2014-03-06 14:20:09 HD Request # 29 - Downloading Intraday chart data for 6EH4 to the file 6EH4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 29 - Download start Date-Time: 2014-03-06 14:15:42.0 | 2014-03-06 14:20:09 HD Request # 29 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:09 HTTP request #7 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:09 HD Request # 28 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:09 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 28 - Error downloading historical Daily data for E6#. There was a communication error with the server. | 2014-03-06 14:20:09 HD Request # 28 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for E6# | 2014-03-06 14:20:09 HD Request # 28 - Daily download COMPLETE for E6# | 2014-03-06 14:20:09 HD Request # 29 - Error downloading historical Intraday data for 6EH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 29 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH4 | 2014-03-06 14:20:09 HD Request # 29 - Intraday download COMPLETE for 6EH4 | 2014-03-06 14:20:09 HD Request # 30 - Downloading Intraday chart data for SIH4 to the file SIH4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 30 - Download start Date-Time: 2014-03-06 12:08:03.0 | 2014-03-06 14:20:09 HD Request # 30 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:09 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 30 - Error downloading historical Intraday data for SIH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 30 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SIH4 | 2014-03-06 14:20:09 HD Request # 31 - Downloading Historical Daily chart data for SI#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:09 HD Request # 31 - Requesting historical Daily Continuous data for SIZ10 starting at 2014-03-04 | 2014-03-06 14:20:09 HD Request # 32 - Downloading Intraday chart data for SIH4 to the file SIH4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 32 - Download start Date-Time: 2014-03-06 12:08:03.0 | 2014-03-06 14:20:09 HD Request # 32 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:09 HTTP request #8 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:09 HD Request # 31 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:09 HD Request # 31 - Error downloading historical Daily data for SI#. There was a communication error with the server. | 2014-03-06 14:20:09 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 31 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SI# | 2014-03-06 14:20:09 HD Request # 31 - Daily download COMPLETE for SI# | 2014-03-06 14:20:09 HD Request # 32 - Error downloading historical Intraday data for SIH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 32 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SIH4 | 2014-03-06 14:20:09 HD Request # 33 - Downloading Intraday chart data for SIH4 to the file SIH4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 33 - Download start Date-Time: 2014-03-06 12:08:03.0 | 2014-03-06 14:20:09 HD Request # 33 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:09 HD Request # 34 - Downloading Historical Daily chart data for CL#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:09 HD Request # 34 - Requesting historical Daily Continuous data for CLZ10 starting at 2014-03-04 | 2014-03-06 14:20:09 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 33 - Error downloading historical Intraday data for SIH4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 33 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SIH4 | 2014-03-06 14:20:09 HD Request # 33 - Intraday download COMPLETE for SIH4 | 2014-03-06 14:20:09 HTTP request #9 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:09 HD Request # 34 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:09 HD Request # 34 - Error downloading historical Daily data for CL#. There was a communication error with the server. | 2014-03-06 14:20:09 HD Request # 34 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL# | 2014-03-06 14:20:09 HD Request # 34 - Daily download COMPLETE for CL# | 2014-03-06 14:20:09 HD Request # 35 - Downloading Intraday chart data for GCJ4 to the file GCJ4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 35 - Download start Date-Time: 2014-03-06 14:18:26.0 | 2014-03-06 14:20:09 HD Request # 35 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:09 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 35 - Error downloading historical Intraday data for GCJ4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 35 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ4 | 2014-03-06 14:20:09 HD Request # 36 - Downloading Intraday chart data for GCJ4 to the file GCJ4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 36 - Download start Date-Time: 2014-03-06 14:18:26.0 | 2014-03-06 14:20:09 HD Request # 37 - Downloading Historical Daily chart data for HGH11. Starting date: 2011-03-28. Service: ta | 2014-03-06 14:20:09 HD Request # 37 - Requesting historical Daily data for HGH11 starting at 2011-03-27 | 2014-03-06 14:20:09 HTTP request #10 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:09 HD Request # 37 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:09 HD Request # 36 - Using server: ds4.sierracharts.com port 10149 | 2014-03-06 14:20:09 HD Request # 37 - Error downloading historical Daily data for HGH11. There was a communication error with the server. | 2014-03-06 14:20:09 HD Request # 37 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HGH11 | 2014-03-06 14:20:09 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 37 - Daily download COMPLETE for HGH11 | 2014-03-06 14:20:09 HD Request # 36 - Error downloading historical Intraday data for GCJ4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 36 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ4 | 2014-03-06 14:20:09 HD Request # 38 - Downloading Intraday chart data for GCJ4 to the file GCJ4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 38 - Download start Date-Time: 2014-03-06 14:18:26.0 | 2014-03-06 14:20:09 HD Request # 38 - Using server: ds3.sierracharts.com port 10149 | 2014-03-06 14:20:09 HD Request # 39 - Downloading Historical Daily chart data for DX#. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:09 HD Request # 39 - Requesting historical Daily Continuous data for DXZ10 starting at 2014-03-04 | 2014-03-06 14:20:09 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HTTP request #11 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-03-06 14:20:09 HD Request # 39 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-03-06 14:20:09 HD Request # 39 - Error downloading historical Daily data for DX#. There was a communication error with the server. | 2014-03-06 14:20:09 HD Request # 39 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DX# | 2014-03-06 14:20:09 HD Request # 39 - Daily download COMPLETE for DX# | 2014-03-06 14:20:09 HD Request # 38 - Error downloading historical Intraday data for GCJ4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 38 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ4 | 2014-03-06 14:20:09 HD Request # 38 - Intraday download COMPLETE for GCJ4 | 2014-03-06 14:20:09 HD Request # 40 - Downloading Intraday chart data for GCG4 to the file GCG4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 40 - Download start Date-Time: 2014-02-26 12:25:31.0 | 2014-03-06 14:20:09 HD Request # 40 - Using server: ds5.sierracharts.com port 10149 | 2014-03-06 14:20:09 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-06 14:20:09 Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09 HD Request # 41 - Downloading Historical Daily chart data for NG. Starting date: 2014-03-05. Service: ta | 2014-03-06 14:20:09 HD Request # 41 - Requesting historical Daily data for NG starting at 2014-03-04 | 2014-03-06 14:20:09 HD Request # 40 - Error downloading historical Intraday data for GCG4. The network socket has been closed. Retrying download. | 2014-03-06 14:20:09 HD Request # 40 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCG4 | 2014-03-06 14:20:09 HD Request # 42 - Downloading Intraday chart data for GCG4 to the file GCG4.scid. Service: ta | 2014-03-06 14:20:09 HD Request # 42 - Download start Date-Time: 2014-02-26 12:25:31.0 | 2014-03-06 14:20:09 HTTP request |
[2014-03-07 00:13:49] |
We recommend restarting your computer and disabling firewall software other than the Windows firewall on your system. This is the relevant error message: Error received in OnConnect while connecting. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2014-03-06 14:20:09
[2014-03-07 01:25:46] |
We also see a very large number of out of order timestamps in some of the chart data files. Here is an example: Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-02-11 11:35:00. Next Bar Date Time: 2014-02-11 11:10:00. Filename: C:\SierraChart2\Data\TFH4.scid | 2014-03-06 14:19:59
You will need to re-download the Intraday data for the affected symbols. For the documentation for this, refer to: http://www.sierrachart.com/index.php?l=doc/helpdetails63.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-07 01:26:05
