Date/Time: Fri, 26 Apr 2024 01:29:13 +0000
Sierra Sim DOM and Market Replay
View Count: 3592
[2014-03-06 18:48:55] |
Discount - Posts: 73 |
Is there some setting I need to check so I can use the DOM and the Market Replay, so the DOM prices will match the Replay Chart I am trying to replay?
[2014-03-06 19:12:58] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#AllChartsInChartbook So the option that you need to enable is For All Charts in Chartbook on the Replay window. Also be sure to take note of the other information in the documentation for this option when it comes to doing replays with Trade DOMs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-07 08:43:40
[2014-03-06 19:22:26] |
Pardon my ignorance, but as I read the Sierra Important comment about back loading days in the DOM, but that is for multiple intra day charts. All I want to do is back test 1 chart with 1 DOM. I have added additional 15 back days. But this did not link the DOM to the Chart I have gone back 15 days in history to back test. Am I missing something? Can you tell me? |
[2014-03-07 05:00:59] |
Figured out what I was doing incorrect. I was trying to use the replay, and the DOM, and keep some charts with Live Data. I went on YouTube, and found my answers. I hope one day Sierra Charts will make Videos, and show how to do things, instead of all this reading and trying to interpret what you actually are saying. Please add this suggestion to your suggestion box, and then it would be very easy for you to respond with a YouTube link. Thanks
[2014-03-07 08:45:22] |
So the option that you need to enable is For All Charts in Chartbook on the Replay window. Also be sure to take note of the other information in the documentation for this option when it comes to doing replays with Trade DOMs. All the charts will be replayed within the Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-07 09:43:30] |
AC94667 - Posts: 5 |
can you post the links for the youtubes videos? I am having the same exact problem, I senable For All Charts in Chartbook, but when I bring up the DOM it is giving me the live DOM and not the reply one! Does this have to do with my data feed? AMP/TT? |
[2014-04-07 16:50:22] |
It does not have to do with the data feed. Follow the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#ReplayingTradeDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
