Date/Time: Thu, 02 May 2024 07:44:03 +0000
Move to Breakeven for Stop Not Working
View Count: 1872
[2014-03-06 17:13:34] |
Futures Operator - Posts: 239 |
v1103, Non CLR, TT, live trading. Stop is set to Move to Breakeven Offset of 1, Trigger offset 10, for All OCO Groups. Testing in Market Replay it works fine, in live trading it does not work/move. |
[2014-03-06 17:52:40] |
We tested this on Rithmic and it works: ActivityType DateTime Symbol OrderActionSource OrderStatus InternalOrderID ServiceOrderID FilledQuantity FillExecutionServiceID TradeAccount OrderType Quantity FillPrice BuySell Price Price2 OpenClose ParentInternalOrderID PositionQuantity
Order 2014-03-06 12:50:33.000 ESH4-CME Auto trail order modification (Move to breakeven). Trigger price: 1874.000000 Pending Modify 270804 7381265 sierrachart Stop 1 Sell 1870.50 Close 270803 1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-06 18:35:51] |
I think I just figured it out. I had chart trade mode off in the chart window where the attached orders stop strategy was selected. I just turned it on, and the stop moved. Is it possible to link the attached orders settings across charts? |
[2014-03-06 19:03:39] |
Yes. That indeed was the problem. There is a reason why it is designed this way and it cannot be changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
