Date/Time: Fri, 03 May 2024 01:14:12 +0000
How to share sc arrays through global variables?
View Count: 1061
[2014-03-06 13:46:26] |
marcovth - Posts: 61 |
Hello ... Is there an easy way to share arrays between studies located in the same cpp file? I tried to use globally declared arrays, but you never know in advance how many bars a chart contains to declare a global array. Thanks for some suggestions. |
[2014-03-06 17:31:54] |
This is possible with the arrays on sc.Subgraph objects. Refer to this page here: https://www.sierrachart.com/index.php?l=doc/doc_ACSILProgrammingConcepts.html#UsingStudyData There are also the sc.Subgraph[].Arrays[] which can be filled in and accessed across studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
