Date/Time: Sun, 01 Nov 2026 00:33:47 +0000
QM Multiplier is incorrect
View Count: 1122
[2021-04-05 15:12:47]
Mattc55 - Posts: 101
For QM, the multiplier is off and orders are going in improperly.
As an example: Instead of 59.20, the position registers as 592.0.
I am pretty sure it's an easy fix, just forgot exactly where to make the change.
[2021-04-05 17:01:57]
We are checking on this now.
[2021-04-05 17:10:48]
The default settings are correct for the Sierra Chart Order Routing Service and CQG. Therefore, the settings within the chart or Trading DOM must not be correct. Follow the instructions here:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
Date Time Of Last Edit: 2021-04-05 17:13:18
[2021-04-06 12:59:06]
Updating the symbol setting per above corrected the issue with how a position displays, but I can only enter a market order. Limit orders get the following error message.
Please let me know. thank you
SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: FIX field incorrect 'Illegal Price: '5808.0 contract 'QMK1' (ticks in 25, CAB of 0)' | ExchID: 8031141868139 | SenderSubID: xxxx. Internal Order ID: 8055. Service Order ID: 5461864. Symbol: QMK21_FUT_NYMEX. Account: xxxx | 2021-04-06 08:56:54.283 *
[2021-04-06 16:13:56]
I tried updating the "trade and current quote symbol price multiplier" in chart settings advanced 3, but that does not seem to be working either.
[2021-04-06 17:50:45]
What is the Chart >> Chart Settings >> Tick size of the chart set to?
[2021-04-06 17:54:28]
.01
[2021-04-06 19:39:03]
That will need to be .025. And then you need to adjust the Price Display Format to .001.
Date Time Of Last Edit: 2021-04-06 19:39:45
[2021-04-06 19:49:50]
Updated, but here is the error.
please note I have it on a CL chart, but QM is the "use as trade only symbol"
SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: FIX field incorrect 'Illegal Price: '58.3 contract 'QMK1' (ticks in 25, CAB of 0)' | ExchID: 8031154416927 | SenderSubID: . Internal Order ID: 8091. Service Order ID: 5467384. Symbol: QMK21_FUT_NYMEX. Account: | 2021-04-06 15:48:14.350 *
[2021-04-09 13:49:28]
Any update on this?
[2021-04-09 15:09:57]
You also need to set up the Trade and Current Quote Symbol Price Multiplier appropriately:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingTradeSymbol
What do you have that currently set to?
Date Time Of Last Edit: 2021-04-09 15:10:51
[2021-04-09 15:29:08]
That was it, I changed it to .001 and it works now, thank you!
[2021-04-11 22:29:56]
On my home PC, I followed all the steps (updated global symbol setting, changed tick size and price display format (.025/.001), and updated 'trade and current quote symbol price multiplier' to .001, all per the above, and am getting the following error message:
SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: FIX field incorrect 'Illegal Price: '5917.5 contract 'QMK1' (ticks in 25, CAB of 0)' | ExchID: 8031211700118 | SenderSubID: . Internal Order ID: 1359. Service Order ID: 5488025. Symbol: QMK21_FUT_NYMEX. Account: | 2021-04-11 18:29:31.111 *
any suggestions?
[2021-04-12 18:08:19]
C_Money - Posts: 90
I have the same issue, sometimes it works and sometimes it doesn't. I have another thread open on this.
FIX field incorrect 'Illegal Price'
Date Time Of Last Edit: 2021-04-12 19:26:07
[2021-04-12 19:02:43]
C_Money - Posts: 90
Matt, I think once you update the settings, you have to save and close everything, and then open it up again. This works for me on SIM, I haven't tried it live yet.
[2021-04-12 19:46:42]
We have gone over this, and we have expanded upon the documentation here for exactly what to do with this symbol combination:
We did do testing on a live account and there were no order rejections with the specified settings.
[2021-04-12 20:02:34]
Ah, it must be that the software on my home PC has not been updated in a while ... will update and try again... thanks.
