Date/Time: Sun, 19 May 2024 01:39:38 +0000
The region between the horizontal lines.
View Count: 1029
[2014-03-06 03:58:40] |
2garin - Posts: 184 |
Good luck to all of the day. I am setting up a personal toolbar (application areas of support / resistance). In the toolbar button added horizontal lines. Questions: How to create (paint) the area between the two horizontal lines? How do I put on the back burner area (chart above)? How to create buttons for different areas of support / resistance? Date Time Of Last Edit: 2014-03-06 04:49:30
[2014-03-06 17:39:14] |
Have a look at using the Rectangle or Extending Rectangle tools: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#RectangleEllipseTools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
