Date/Time: Sun, 05 May 2024 21:42:08 +0000
Incorrect parsing of Env Variable VS140COMNTOOLS
View Count: 1916
[2021-04-03 18:12:00] |
autobahn - Posts: 25 |
When compiling a custom study locally, the environment variable VS140COMNTOOLS is used to determine the location of vcvarsall.bat. Visual Studio Build Tools 2017 uses the following location for vcvarsall.bat: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\VC\Auxiliary\Build\vcvarsall.bat
However, specifying this path in the environment variable always results in VisualCCompile.bat incorrectly trying to use the following location: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\VC\Auxiliary\Build\VC\vcvarsall.bat
This is because Sierra Chart (2245 64-bit 36772) always adds \VC to the end of the path. This was correct operation for VS2015, but incorrect for VS2017 and VS2019. A workaround is to create a dummy vcvarsall.bat file that SierraChart can locate, and have that dummy file call the proper vcvarsall.bat file. |
[2021-04-03 18:13:29] |
Note for anybody else experiencing this issue: When you change the environment variable, it is necessary to completely exit and restart Sierra Chart for the new variable to take effect.
[2021-04-05 15:39:59] |
This is because Sierra Chart (2245 64-bit 36772) always adds \VC to the end of the path. This was correct operation for VS2015, but incorrect for VS2017 and VS2019. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-05 15:40:13
[2022-01-20 16:42:00] |
User217027 - Posts: 5 |
Hello, I'm afraid the problem still persists in SC 2347 40792M
[2022-03-06 20:13:57] |
We apologize for the delay. We are going to review this.
