Date/Time: Sun, 05 May 2024 11:28:01 +0000
VWAP start time problem
View Count: 1732
[2014-03-05 21:39:59] |
rhovega - Posts: 279 |
Hi Sierra Team, I'm having problems with the Volume Weighted Average tool. I changed the start time in the tool's menu, but the start time does not change in the chart (it remains starting at 00:00). Any ideas what he problem may be? I tested this on 1min and 5min charts with VWAP set for 1 day (default setting). I also forced a chart refresh to try to get it sorted, but no luck. Noticed the following thread covering the VWAP start time subject: https://www.sierrachart.com/supportboard/showthread.php?t=42239&highlight=vwap. Could not figure how to make a reply on the thread. My apologies for that. Screenshot attached. Many thanks |
screensh.JPG / V - Attached On 2014-03-05 21:39:47 UTC - Size: 205.92 KB - 339 views Attachment Deleted. |
[2014-03-07 02:23:59] |
You need to set the Session Times within Chart Settings: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-19 17:32:59] |
User99689 - Posts: 27 |
Yes it right but how then using 2 vwap for us and europeen sessions for ex in the same chart ? |
[2014-03-19 17:54:05] |
You cannot.
[2014-03-19 18:43:37] |
NRGTrader - Posts: 351 |
Use overlay study on your main chart from vwap study on a chart using the second time frame, e.g., European session.
[2014-03-19 20:39:07] |
As has been said in the prior post, you could set up another Volume Weighted Average Price study as you require on another chart and overlay it to a different chart. Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-20 10:33:18] |
Ok TBondTrader & support, good idea. Thanks you. |
