Date/Time: Sat, 04 May 2024 07:45:06 +0000
candles with numbers bars
View Count: 1148
[2014-03-05 20:43:13] |
chris12 - Posts: 51 |
HI SC How can i make appear candles in the background of my numbers bars like example?? thx |
Capture d’écran 2014-03-05 à 21.42.33.png / V - Attached On 2014-03-05 20:43:08 UTC - Size: 23.81 KB - 419 views |
[2014-03-05 23:30:38] |
Sierra Chart does not offer this. Instead you can add small boxes to the left side. Refer to "Open and Close Marker Style" here: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#InputSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-05 23:30:53
