Date/Time: Tue, 07 May 2024 09:18:45 +0000
The quotation of XRP.USD perpetual futures in BitMEX seems wrong
View Count: 810
[2021-03-30 15:58:46] |
User720123 - Posts: 15 |
Hello, The quotation of XRP.USD perpetual futures in BitMEX seems to be wrong. In BitMEX, the minimum price increment of this futures contract is 0.0001 USD, but it appears to be 0.01 USD on Sierra Chart. The DOM of this contract is also affected. http://www.sierrachart.com/image.php?Image=1617119126322.png |
[2021-03-31 03:31:01] |
You need to change the Price Display Format and Tick Size in Chart Settings: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-31 03:31:28
[2021-04-03 00:29:47] |
Hello, I followed the instruction and the price can display correctly like in the previous versions. However, the DOM chart still has some problem. Following the instruction, the price display of DOM chart is now to the correct 4th decimal, but the volume of the buy and sell orders does not match those appeared in BitMEX. There has not been such a problem in the previous versions. How to solve this? Can you fix it in the upcoming version? |
[2021-04-03 03:06:13] |
We apologize for this. This is now resolved. Follow the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Be sure to update the Symbol Settings first as explained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-14 13:43:52] |
Hello, I am facing the same problem with the DOGE.USDT perpetual futures contracts in BitMEX now as I was with the XRP.USD futures contracts. The minimum price increment of this futures contract is 0.00001 USD, but it appears to be 0.01 USD on Sierra Chart. The DOM is affected as well. The XRP.USD problem was solved after the update. Please see to it, thanks! |
[2021-05-16 05:07:18] |
We set up specific symbol settings for this symbol now. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-16 05:07:33
