Date/Time: Sat, 31 Oct 2026 07:18:02 +0000
Control Bar 1
View Count: 801
[2021-03-29 22:17:08]
User707404 - Posts: 34
I recently came back to Sierra Charts, before I had an icon that would give me the amount of Currency value between two points on the chart. But I do not see it in the Tool list anymore. There is a Reward tool but that is not what I had before. I just want to measure between two points on any chart. Where can I find it and add it to my Control Bar 1 again? Thanks. Robert
[2021-03-30 13:45:41]
It sounds like you are looking for the Chart Calculator which has the option to display various information between two points, including Currency Value. Refer to the information here:
Chart Drawing Tools: Chart Calculator
Also refer to the following for how to create the Control Bar button that selects the tool and the Configuration:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
