Date/Time: Fri, 03 May 2024 01:17:23 +0000
Symbol is unknown
View Count: 1015
[2014-03-05 07:15:18] |
User31732 - Posts: 32 |
Hello, i can't open fgbl june 14 contract. I use cts and SC ver 1102. Please help. |
[2014-03-05 07:59:31] |
This problem has to do with a change in the symbol format by CTS. We hope to have this resolved either today or tomorrow. Tomorrow at the latest.
[2014-03-07 06:09:51] |
User33542 - Posts: 1 |
Проблема так и не решена. Пожалуйста, проясните ситуацию. Спасибо.
[2014-03-07 06:32:46] |
Hello, Problem is still there. |
[2014-03-07 08:07:15] |
We are making this a priority to get this resolved. It has to do with symbol changes on the CTS side. We are actively working on it. We will have a solution out by the end of the day today. So the solution will be ready by Monday morning. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
