Date/Time: Sun, 05 May 2024 05:25:50 +0000
Sierra Chart Engineering - Summary window
View Count: 936
[2021-03-28 14:53:42] |
Ackin - Posts: 1865 |
Summary window - Could you please consider adding one row in the table header (optional item in the settings). A new number for each column. When switching to another window and back to the summary window, it is sometimes time consuming to find the desired column again. Thank you |
[2021-04-20 03:57:26] |
We will look into this.
[2022-04-21 08:30:10] |
Sierra Chart Engineering) Any news on this request? |
[2022-04-21 12:39:48] |
We will see if we can get this done today for you. Sorry for the long delay.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-21 12:39:55
[2022-04-21 13:04:17] |
So you want to have numbers in the column headers like 1, 2, 3, 4?
[2022-04-21 13:46:13] |
yes exactly, with a lot of columns and scrolling to the side it is easier to remember the column number than to constantly read the column name again.Thank you |
[2022-06-15 13:01:32] |
This has been added. It was done over a month ago. Enable this option on the Study Summary window: Settings >> Display Column Numbers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-15 13:01:47
