Date/Time: Sun, 08 Nov 2026 19:31:48 +0000
AMP futures Sierra direct routing
View Count: 1020
| [2021-03-26 13:22:37] |
| User99934 - Posts: 227 |
Does AMP support the Sierra order routing service? Manager there said I have to use CQG. I don't want to use CQG. They have TT.
| [2021-03-26 13:38:59] |
Not at this time. You need to use CQG or Rithmic with AMP. If you want to use the Sierra Chart Order Routing Service, then refer to step 2 here for supported brokers: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-26 13:39:24
