Date/Time: Sun, 05 May 2024 17:08:52 +0000
market depth combine increment in ticks
View Count: 1794
[2021-03-23 15:28:08] |
User356762 - Posts: 37 |
Hello, i found your guy's market depth combine increment in ticks and was wondering if there was a way to combine the recent bid/ask columns, pulling stacking columns etc (on the DOM)when this setting is clicked. so for example if i have the NQ setting set to 1 tick and the chart setting tick size to 1 as well, the market depth is combined at 4 ticks. however, the pulling columns or recent bid/ask volume columns are still 1 tick so it sort of defeats the purpose for the DOM. if there is no way to combine the rest of the columns currently, would you guys consider adding this function? TIA |
[2021-06-20 00:38:29] |
User422433 - Posts: 18 |
Looking for an answer to this same question
[2021-06-21 13:28:12] |
John - SC Support - Posts: 31379 |
We have marked this as a Feature Request. It is not currently available, and we will add it to our list of work to do, but we can not say when we will be able to get to it.
[2021-07-18 12:05:49] |
Br4m_H4 - Posts: 2 |
+1
[2021-11-23 00:04:39] |
User293778 - Posts: 17 |
+1
[2022-01-12 08:21:20] |
Nikhil Patil - Posts: 2 |
Did you add this feature?
[2022-03-23 18:03:42] |
sean3000 - Posts: 37 |
+1 Combining market depth levels is a great feature, but in its current state it makes all other DOM columns unreadable. |
[2022-04-12 02:45:48] |
ebfsantos - Posts: 4 |
Has this feature being implemented?
[2022-04-18 11:02:06] |
Hi SC, I have seen that this feature already works if you set the symbol tick size in Global Symbol Settings, although in this case there are still a few minor issues, like LTQ doesn't work when shown in Current Traded Total Volume, because it displays only every tick-size steps, although it does indeed work in all levels if shown alone. Recent and Current Volumes do seem to work combined. But strangely nothing works (LTQ, Recent and Current volumes) if you set the tick-size on a per chart basis in its corresponding Settings window or use the market depth combine parameter. Please, it would be great that you guys got this feature working properly because that would be especially useful for less liquid instruments. Thanks! |
[2023-07-15 14:19:45] |
User861257 - Posts: 12 |
This feature which would combine Recent Bid/Ask and Pulling/Stacking would be a massive upgrade and so practical for the equities data feed you just released. Please prioritize. Thank you Sierra Chart
