Date/Time: Fri, 23 Oct 2026 11:39:17 +0000
How can I tell if I am connected to the Denali Data Feed?
View Count: 1704
| [2021-03-22 18:28:49] |
| HeidiT - Posts: 16 |
Hi, I just changed to service package 11 and added exchange data. Im still using CQG order routing. I cant tell if I am running the Denali data or not. How do I find that out. Thank you!
| [2021-03-22 20:44:04] |
| John - SC Support - Posts: 48303 |
Refer to the information towards the bottom of this section where you look for the [M] after the symbol: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
