Date/Time: Fri, 23 Oct 2026 11:41:21 +0000
NumbersBars - AdjustingTickSizeForLargerIncrement
View Count: 888
[2021-03-22 18:01:23]
User480912 - Posts: 7
Numbers Bars: Adjusting Volume at Price Multiplier For Larger Increment
As an engineer and being around a zillion engineers and coders, I won't be surprised if received a dismissive response, but I will still go ahead and make my request.
You suggested a workaround to adjust the tick size for the Number Bar, and I would kindly ask that you consider implementing a feature similar to the one already include in the VbP (Ticks Per Volume Bar).
[2021-03-22 20:32:26]
John - SC Support - Posts: 48303
Essentially there is that option. It is in the last paragraph of the section you referenced where you can change the Volume at Price Multiplier for the chart. You will find the documentation for this here:
Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu)
