Date/Time: Tue, 20 Oct 2026 03:56:04 +0000
Rollover into a new contract with drawings
View Count: 1710
| [2021-03-21 14:25:06] |
| User437588 - Posts: 92 |
Hello After rollover into a new contract, the subscriptions were taken over as well. Due to the interest rate difference there is a deviation in the drawings. With the tool Manage Drawings you can make an adjustment. I have tried all but the drawing have not changed. What is the exact step to adjust the drawings to the new contract? Thanks http://www.sierrachart.com/image.php?Image=1616336589447.png |
Attachment Deleted. |
| [2021-03-22 15:00:33] |
First use this Chart menu command to make sure the Chart Drawings are using the correct symbol: Chart Menu: Update Chart Drawings to Current Symbol (Chart menu) Here is the updated documentation to adjust the Chart Drawings: Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-22 15:00:57
| [2021-04-23 17:58:53] |
| whats1thingnow - Posts: 418 |
is there an easy way to find out what the adjust amount should be? i used the values from https://www.barchart.com/futures/indices for the difference between the contracts and they don't match up.. so within sierra itself, is there a way to find out the difference in points between the old contract and new contract? thank you very much |
| [2021-04-26 02:50:57] |
Yes you can determine this through the Message Log. Refer to: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-04-26 03:00:17] |
thank you for your reply specificically for VX rollover (from VXJ21-CFE to VXK21-CFE), i got the following: VXK21-CFE [CB] 30 Min #60 | VXJ21-CFE price difference to VXK21-CFE is 3.2. | 2021-04-25 22:28:57.723 VXK21-CFE [CB] 30 Min #60 | Back adjust amount for symbol VXJ21-CFE is 3.2. | 2021-04-25 22:28:57.723 however, the drawings are still off using the value 3.2 adjust amount any ideas what could have gone wrong? |
