Date/Time: Sun, 05 May 2024 20:43:29 +0000
INV in Trade Activity Log
View Count: 1200
[2014-03-03 17:08:27] |
corbeste - Posts: 74 |
Hi, I am seeing INV and junk numbers under the MAE/MFE stats in my activity log. I am trading via OEC, live. Its pretty important as I export these figures to Excel for my trading stats. Thanks, Steve |
03-03-2014 18-07-20.png / V - Attached On 2014-03-03 17:08:15 UTC - Size: 6.18 KB - 497 views |
[2014-03-03 20:21:13] |
Futures Operator - Posts: 239 |
I have the same issue since around last week using TT in live trading. Looking at these entries in the Trade Activity tab using Edit, there are order fills that have Open/Close reversed, and High/Low during positions shows this: "-1.$". Date Time Of Last Edit: 2014-03-04 03:51:19
[2014-03-06 03:39:57] |
Post #1 response: This is because there are invalid values for the High and Low prices which were recorded during the Trade Position. Why that is the case we do not know. Unless it is a consistent and reproducible problem, there really is not much we can do other than to recommend that you correct the values by editing the order fills in the Trade >> Trade Activity Log >> Trade Activity tab. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#MenuCommands If the problem continues to occur, let us know and then we can try to reproduce it or if you can give us the steps to reproduce it that would be good. We wonder if there was invalid values coming through with the market data from OEC. That might have been the case . This is a problem we are looking into. Although we have not seen anything recently in the past week with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-06 03:41:28
[2014-03-06 03:43:18] |
Disregard post #3. We can see the problem that you are now referring to. We will fix this. there are order fills that have Open/Close reversed, This can and will be the case from a TT FIX adapter which does not carry overnight positions.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-06 04:39:08] |
We have released version 1003 which should resolve this problem. Please update and let us know if the values in this Trades tab now are correct: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=2170 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-06 04:39:54
[2014-03-06 16:32:45] |
This has resolved the issues, thanks.
