Date/Time: Tue, 07 May 2024 00:43:44 +0000
Dax 30
View Count: 1117
[2014-03-03 15:13:02] |
User54027 - Posts: 128 |
Hello support, I am getting huge lag on dax and US Dow Jones charts......please advise Justin |
[2014-03-03 18:08:30] |
How is it that you are determining the lag? Are you noticing the problem now. We do not see a delay at the present time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-03 18:52:24] |
Hello, The issue seems to have resolved...will keep you updated if it persists. Many thanks. |
[2014-03-03 19:41:02] |
We would like to know though how you determined that there was a lag? This is important for us to help understand where the source of the problem was.
