Date/Time: Sun, 19 May 2024 06:58:52 +0000
I placed an order but could not cancel.
View Count: 376
[2021-03-17 02:22:38] |
User679347 - Posts: 4 |
Hello I have CQG connection and I placed an order and could not close it, I thought this was an issue with Sierra Chart app, so I closed it. When I re-opened the app, the position was negative and I was not able to close it. I downloaded the latest version and still nothing. I then got an email from AMP about CQG having some issues. I can't cancel or do anything at this point. |
[2021-03-17 08:48:33] |
You need to contact your broker for help with this. This is not a Sierra Chart issue.
