Date/Time: Thu, 15 Oct 2026 14:12:50 +0000
Scaling Help
View Count: 951
[2021-03-16 04:44:04]
User161806 - Posts: 18
Hi there,
For some reason any time I adjust something in my studies or refresh my charts the scale range changes from 'Constant Range' to 'Automatic' scale
I would like to keep this particular chart (please see image) in the 'Constant Range' scale
Is there a way to make 'Constant Range' scale default for this chart so that it does not keep reverting back to 'Automatic' scale?
Thanks very much for your time.
Josh
imageScreenshot 2021-03-16 143742.png / V - Attached On 2021-03-16 04:43:03 UTC - Size: 72.35 KB - 300 views
[2021-03-16 10:49:42]
You must be using a custom study which is doing this. You need to remove that study from the chart. Refer to:
Chart Studies
