Date/Time: Fri, 26 Apr 2024 13:54:04 +0000
delayed feed
View Count: 1109
[2014-03-03 09:12:22] |
stephensmart - Posts: 51 |
I am experiencing a delayed data feed on spot forex this morning?
[2014-03-04 08:50:28] |
Are you still noticing a problem? And if you do, please let us know how you know that the data is delayed. So we can understand the basis of this.
[2014-03-04 09:14:08] |
Hi, it has been resolved today, was delayed the entire day yesterday, the price on the charts was delayed from between 10 sec to up to 1min, i was observing eurusd and the feed was delayed to the actual market i was trading on.
[2014-03-04 09:33:27] |
OK, this is possible this originated from the FXCM side. When you notice this problem, what you need to do is to make sure your computer's clock is set accurately down to the second and then compare the last trade time for the symbol as seen in Window >> Current Quote Window to the time on the title bar of Sierra Chart. When there is a trade received, those two should match. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
