Date/Time: Fri, 03 May 2024 03:52:45 +0000
V and H lines snaping to round numbers
View Count: 1025
[2014-03-03 04:18:14] |
User87794 - Posts: 10 |
Hi I place either a Vertical or Horizontal line on my chart. When I go to move the live it snaps to a whole round number i.e. if it is placed at .8912 and I move it up it will snap to .9000. Both Vertical and Horizontal are behaving in the same manner. What setting do I need to change to stop this. thanks Randell |
[2014-03-03 07:43:31] |
Refer to Having Tool Values Adjust to the Nearest Tick: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ToolValuesAdjustToNearestTick You will want to disable this option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
