Date/Time: Sun, 19 May 2024 00:04:23 +0000
[User Discussion] - GOOD DAY !
View Count: 447
[2021-03-11 02:51:12] |
User413489 - Posts: 19 |
GOOD DAY ! WHAT SERVICE DO I NEED TO CONNECT TO MAKE QUOTATION TABLES WORK ON TWO COMPUTERS ?
[2021-03-11 14:47:29] |
We see that you are subscribed to the U.S. Equities exchange. If you are only using one computer at a time, then you just need to ensure that you have fully exited from Sierra Chart on the one computer before going to the other computer. As long as you only have one connection at a time, then this is not a problem. It is not possible, however, to access the data on two different computers at the same time from one account. The only option would be to create a second account and subscribe that second account to the Sierra Chart Exchange Data Feed with the U.S. Equities as well. You would then use that second account on the second computer. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
