Date/Time: Sat, 18 May 2024 14:10:14 +0000
[Programming Help] - Adding a downloaded study when using a Mac/Codeweavers
View Count: 525
[2021-03-10 18:59:55] |
User789550 - Posts: 17 |
Can a dowloaded study be added to Sierra Charts when you are on a Mac and have used Codeweavers to make it run ? There is no file directory I can fine to add the study to Is there another way ? Thanks in advance |
[2021-03-11 01:23:14] |
User584084 - Posts: 241 |
Start Codeweavers Crossover. Go to the Codeweavers Crossover menu (upper left of the Mac screen). Find the Bottle menu item. Select the Bottle menu. Select Open C: Drive. A drive_c finder window will open. You will see the Sierra Chart directory. Click on the Sierra Chart directory. Find the Data directory and add your study to the Data directory. Or you can also get to C: drive from the Codeweavers Crossover window. There is list of Bottles. Highlight the Sierra Chart Bottle. Right click and select Open C: Drive. |
