Date/Time: Sun, 05 May 2024 05:07:45 +0000
Chart loaded, but symbol not available in Global symbol setting
View Count: 925
[2014-03-03 00:29:42] |
NumbersBars - Posts: 141 |
Data: OEC Sierra chart version: 1077 I managed to load ZNM4 in sierra chart. However, when I try to edit session hour in Global symbol setting, ZNM4 is not available in the symbol list. I have tried to disconnect/reconnect, or shutdown/restart... (note, I tried version 1099, it is worse, the chart is not even loaded probably, I know there is a long battle between OEC FIX and new Sierra chart,so I stick to 1077 for now.) I have attached the screenshot of Global symbol setting. Please advise is there anything I missed out or how do I find ZNM4 from the symbol list. |
2014-03-03_11-19_Global Symbol Settings.jpg / V - Attached On 2014-03-03 00:28:44 UTC - Size: 229.22 KB - 337 views Attachment Deleted. |
[2014-03-03 00:44:12] |
In this particular case, we recommend performing a Full Reset of the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-03 00:44:44
