Date/Time: Sun, 28 Apr 2024 06:41:36 +0000
Customized Coloured Candles
View Count: 1832
[2013-04-20 20:23:10] |
T44 - Posts: 363 |
Would it be possible to provide a customizing function so that the candles on each chart can be coloured differently, as is available in eSignal? In SC I can find a way to change candle colour but it is within Global Settings and all charts must then use the same candle colour. Thanks. |
[2013-04-20 21:21:51] |
Sawtooth - Posts: 3980 |
Go to Chart >> Graphics Settings, uncheck Use Global Graphics Settings..., then set the colors to your choice.
[2013-04-20 21:36:13] |
This is supported. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
