Date/Time: Sun, 05 May 2024 07:19:32 +0000
Eurex delayed data
View Count: 500
[2021-03-10 12:34:11] |
User472704 - Posts: 34 |
Hello ! I'd like to trade EUREX with the trading evaluator delayed service. Is it possible to make it work ? Thank you |
[2021-03-10 16:19:17] |
We have to set this up. We will do that this evening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-10 16:27:21
[2021-03-10 18:11:00] |
Thank you for your work
[2021-03-11 14:39:53] |
This is being delayed. We had a problem with the latest update. This will be completed at the end of the day today.
[2021-03-11 21:47:00] |
This update is now done.
[2021-03-12 16:41:42] |
It works. Thank you
