Date/Time: Sat, 18 May 2024 14:10:21 +0000
Playback sync issue with different time frames
View Count: 727
[2021-03-09 20:12:17] |
User290496 - Posts: 56 |
Hello, I have multiple time based charts open (5min, 60min, 120min etc). Some are ETH, others RTH. When I start a replay on my main chart, the 5 min- the other charts begin playing from the same time/date as well. Which is what I want. However- when playing back at a speed faster than 1x, sometimes one or more of the other charts will lag behind, and the price ladder will be at a different price than the main 5min chart. In addition- sometimes I click 'Pause' on the replay of the 5 min chart, but one or more of the other charts will not pause and keeps playing back. So I click on that other chart (e.g. 60min) that did not pause- and hit 'Pause' on the replay window, which pauses the 60min chart, but then the 5min chart starts to playback. So now I have some charts paused, some charts that are playing back- and everything is out of sync. The intention being to have them all playback and pause at the same time. Date Time Of Last Edit: 2021-03-09 20:14:11
[2021-03-09 20:24:22] |
Refer to the following: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#PreventingLossOfSynchronizationBetweenDifferentChartsDuringReplay For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-10 00:56:36] |
This does not seem to work, or introduces another issue- What I am doing: Start playback on a ETH chart at 07:00:00 AM, all charts that are ETH start playing back fine at 07:00:00 AM. However- 5min RTH chart of the ES starts playing from 09:30:00 AM. So I have a bunch of ETH charts playing back from 7am, but my RTH charts all are starting to playback from 9:30 AM at the same time- when what should happen is that those RTH charts should sit idle until playback hits 9:30am on the other charts. If I go back and uncheck 'Skip Empty Periods', then this new issue goes away- but I am left with the old one mentioned in my previous post- where they all start off playing at the same time, correctly- but then fall out of sync if the time is sped up- and also some will not pause when the pause button is pressed. Date Time Of Last Edit: 2021-03-10 00:58:50
[2021-03-10 20:40:16] |
There is no support for what you are wanting to do.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-10 20:40:41
[2021-03-10 21:44:41] |
Sawtooth - Posts: 4000 |
I only notice any lag between charts when I use Standard Replay. Charts seem to stay synced when using these settings and methods: -Charts to Replay: All Charts in Chartbook -Replay Mode: Accurate Trading System BackTest Mode -Skip Empty Periods is unchecked. Also: -Only use Replay panel from one main chart -Always focus the main chart when Pausing and Playing. -Never Pause and move chart further in the past; Always Stop and restart replay to move chart into the past. -Always do everything from the one main chart. |
