Date/Time: Thu, 26 Nov 2026 03:31:16 +0000
ADMIS Broker Question
View Count: 1028
| [2021-03-09 16:11:06] |
| silvereagle - Posts: 23 |
I am new to Sierra and I have been reading the documentation and forums and saw that Sierra (Denali) does not work with ADMIS broker due to ADMIS (one of the largest and safest) not using TT. From what I understand Sierra used to support CQG Data and execution but no longer Data. I also read that if you want to trade foreign markets (which I do) you still need CQG. 1. Data ??? 2. Execution (CQG) Is it still possible to use CQG Data despite "known issues?" or should an alternative like Rithmic be used? I'm still putting the pieces together and their respective costs so advice on how to cost effectively get set up using ADMIS is very welcome! Thanks for the help. Curt |
| [2021-03-09 16:35:17] |
This is not true. The Denali Exchange Data Feed works on its own, and with all supported Trading services. What you actually are referring to is the Sierra Chart Order Routing Service which currently uses TT. If you are going to use ADM, then you need to use CQG for order routing but do use our Denali data feed with CQG: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-09 16:35:54
| [2026-03-12 01:09:06] |
| Foreman Capital - Posts: 8 |
Is this still the case?
| [2026-03-12 14:23:59] |
We no longer use TT for our own order routing. It is now done directly by us. Refer to the following: Sierra Chart Teton Futures Order Routing As to ADM, if they still support CQG, then you can use CQG for the order routing with them and use our Denali Exchange Data Feed for the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
