Date/Time: Thu, 02 May 2024 03:53:30 +0000
indicator
View Count: 2635
[2014-03-01 21:24:00] |
User51166 - Posts: 33 |
Hello there, is possible add into sierra chart in next release accumulation/distribution indicator Accumulation/Distribution (A/D) A momentum indicator which tries to gauge supply and demand by discovering if investors are generally 'Accumulating' (buying) or 'Distributing' (Selling) a certain stock by identifying divergences between stock price and volume flow.Refers to A momentum indicator that attempts to gauge supply and demand by determining whether investors are generally “accumulating” (buying) or “distributing” (selling) a certain stock by identifying divergences between stock price and volume flow. It is calculated using the following formula: Acc/Dist = ((Close – Low) – (High – Close)) / (High – Low) * Period’s volume. Refers to an OEC Trader Charts drop-down item. http://www.openecry.com/traderstoolbox/OECTraderGuide/current/whgdata/whnvp33.htm ?????????????? Regards Rene Date Time Of Last Edit: 2014-03-01 21:26:27
[2014-03-02 02:01:33] |
vegasfoster - Posts: 444 |
It's already there.
[2014-03-02 06:42:15] |
there is accumulation / distribution flow (Close - Open) / (High - Low) * Volume is similar name but different formula for calculation. |
[2014-03-02 23:00:23] |
M5amhan - Posts: 468 |
use color bar based on alert condition and type this into the alert tab: =((C-L)-(H-C))/(H-L)*V
then in settings and inputs change "Output when condition is used" from "1.0" to "Use input data" then change draw style to line |
[2014-03-03 08:00:47] |
This is very easily added. We will add a new study with the name: Accumulation/Distribution With this formula: Accumulation/Distribution = ((Close – Low) – (High – Close)) / (High – Low) * Bar Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-03 12:38:03] |
Thank you for your respond , I tried M5amhan (thanks mate) way but SierraChart against Open e Cry Trader looks completely different ,so if you can testing result against OEC trader (range bar). I looking this indicator for back testing. Rene Accumulation/Distribution Acc/Dist = ((Close – Low) – (High – Close)) / (High – Low) * Period’s volume http://www.openecry.com/traderstoolbox/OECTraderGuide/current/whgdata/whnvp33.htm Date Time Of Last Edit: 2014-03-03 12:39:12
[2014-03-05 21:48:57] |
Either we programmed this wrong or this is a completely illogical formula that does not produce a reasonable result at all: Acc/Dist = ((Close – Low) – (High – Close)) / (High – Low) * Period’s volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
