Date/Time: Thu, 02 May 2024 22:22:33 +0000
platform issue
View Count: 929
[2014-03-01 16:57:08] |
bwalks123 - Posts: 122 |
I had SierraChart running yesterday 02-28-2014 and out of no where all of the button tabs in the main screen started slowing down (file,edit,chart,analysis ect.....) When i would click on say "file" it would just pull up a blank window with nothing showing and the only way to get everything to populate was to run my mouse over the window? I have an extremely fast computer and was running SC version 1097. I tried updating today to version 1099 but still getting the same issue? Thx
[2014-03-01 19:02:47] |
Refer to help topic 30 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails30.html We want to know what the CPU usage is of the SierraChart.exe process. More information about that is explained in this section here: https://www.sierrachart.com/index.php?l=doc/helpdetails4.html#h4.3 Another simple thing to do is to restart your computer and see if that makes a difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-01 19:03:05
