Date/Time: Sat, 18 May 2024 18:05:28 +0000
Last version of SC worked fine with Rithmic DTC Bridge?
View Count: 868
[2021-03-08 14:44:08] |
User194514 - Posts: 5 |
Hello Support Team, can you please tell me the last version of Sierra Chart that worked fine with the last Rithmic DTC Bridge from 07/14/2020? Thank you very much. |
[2021-03-08 15:42:43] |
We do not know why there would be a problem with the current version. So we cannot answer this question.
[2021-03-08 16:16:27] |
The Rithmic data feed is interrupted after 10 seconds, then it takes a few minutes again until a reconnect has taken place. In the message log I can read, that the Bridge process is not running. So I thought, the Bridge would no longer work with newer versions of SC, hence the question. Unfortunately, like so many others, I have to use the Rithmic data feed for a combine to get a funded account. And unfortunately, there is no longer any support from your side regarding issues with Rithmic, or has something changed? |
[2021-03-09 01:53:42] |
Sawtooth - Posts: 4000 |
Have a look here: Problems with the DOM and here: Latest version not showing levels on the DOM - (With Rithmic DF) |
