Date/Time: Mon, 20 May 2024 23:19:32 +0000
[User Discussion] - Latest version not showing levels on the DOM - (With Rithmic DF)
View Count: 936
[2021-03-08 11:14:46] |
User75949 - Posts: 108 |
Hi, just noticed the latest version (and the pre-realise) don't show levels on the DOM, just one level, I'm using Rithmic datafeed Went back to 2226 Version and it works great as usual. Could you please give a look at it? Tks regards |
[2021-03-08 17:24:42] |
We do not know why this is the case with Rithmic.
