Date/Time: Fri, 26 Apr 2024 19:26:31 +0000
[User Discussion] - Spreadsheet trading exit question
View Count: 1167
[2014-02-28 19:44:11] |
User14682 - Posts: 83 |
How do I make sure that when I exit, the entire position is liquidated? Quantity is set at 2 but sometimes I have a position of 4.... I have implemented 2 exits, although sometimes they trigger on the same bar, not fully exiting the position.. Please help.. Current buy exit example : =OR(AND(AA3<AG3,AA4>AG4),AND(AA3<AI3,AA4>AI4)) |
[2014-03-01 03:15:04] |
vegasfoster - Posts: 444 |
You need to put a formula in J26 to control the quantity. I would do something like split your signals, for example put one in column O and one in column P and return 2 if true and 0 if false, then in colmumn K say if either O or P are 2 then true, and in J26 put O3+P3 to give either 2 or 4.
[2014-03-04 00:34:14] |
In the Order Quantity cell you will want to set it to 0 and then the full position will be Flattened with the Exit signal.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-04 00:34:37
