Date/Time: Sun, 19 May 2024 11:06:11 +0000
symbol settings not found for current service
View Count: 1036
[2021-03-07 22:10:57] |
User999647 - Posts: 38 |
I am subscribed to SP indices and actually some SP indices work well on charts, for example $INX and $IGX show up in charts. However, some indices that I need (for example $SSCO, $X2BD and $X2HB) do not show up. Instead it says the error message above. Any solution to have them show up? Thanks a lot. |
[2021-03-08 10:47:33] |
Sierra_Chart Engineering - Posts: 14423 |
We added the necessary Symbol Settings for these symbols. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-08 10:47:38
[2021-03-08 11:17:14] |
that works, thanks
