Date/Time: Sat, 18 May 2024 16:33:28 +0000
MD5 Errors
View Count: 731
[2021-03-06 19:13:27] |
User115740 - Posts: 12 |
I have attempted to install both the current version and pre-release version of SC and I keep seeing a large string of MD5 errors that suggest restarting the installer. I have done so and I continue to get the same error. Any suggestions? First time running into this issue.
[2021-03-06 19:59:23] |
Artykwolf - Posts: 1 |
I have attempted to install both the current version and pre-release version of SC and I keep seeing a large string of MD5 errors. I recently installed Kaspersky Total Security and also tried with the protection disabled. I pressed the Send Log to Support and sent the example.
[2021-03-06 20:21:29] |
JohnR - User831573 - Posts: 300 |
I'm getting the same MD5 not matching errors - I have not changed anything on my system. I tried 3 times and did a reboot between try 2 & 3. I do have BitDefender installed, but it has been on my system for years. JohnR |
[2021-03-06 20:27:29] |
David233310 - Posts: 1 |
Sorry that was old demo account Artykwolf [Direct Messages] - Posts: 1 | Ending Date: 2018-08-11 [Expired] I have attempted to install both the current version and pre-release version of SC and I keep seeing a large string of MD5 errors. I recently installed Kaspersky Total Security and also tried with the protection disabled. I pressed the Send Log to Support and sent the example. I used the ZIP installer and that worked OK. |
[2021-03-06 20:51:57] |
We are checking on this now.
[2021-03-06 21:04:51] |
There is a problem on our side. Give us about 10 minutes to resolve. For now use the ZIP installers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-06 21:04:56
[2021-03-07 00:06:59] |
This has been resolved earlier today.
