Date/Time: Mon, 27 May 2024 15:53:13 +0000
Multiple questions
View Count: 488
[2021-03-06 12:34:05] |
User431006 - Posts: 4 |
-I have a trading account (rithmic) which I use with other softwares. If I subscribe to package 11, I need to connect only once a month to validate for the lower-priced fees (CME). And I'm still be considered a nonprofessional. Correct ? -Do you have information on the availability of a new rithmic bridge, it allows the connection via R Trader Pro ? -EUREX Denali Top of book will it be proposed ? -Would it be possible to send real-time data from Sierra Chart (Denali) to other trading softwares via the DTC Protocol ? Thx, |
[2021-03-08 15:18:31] |
John - SC Support - Posts: 31885 |
1. Correct, as long as you connect to your Rithmic account once a month, that will take care of the requirement from the CME Group for a Futures Trading Account. 2. The new implementation by Rithmic for connectivity to Sierra Chart is still being worked on. That is all we know. You will have to ask Rithmic for their status. 3. If you are getting EUREX data from us, then you have access to the full order book. 4. No, this is not supported. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
