Date/Time: Sat, 18 May 2024 19:03:31 +0000
SC very slow
View Count: 524
[2021-03-06 06:01:20] |
nicktrader - Posts: 665 |
I have four linked charts open and also use the QuoteBoard. I use very few Studies (max5) and max 30 days loaded. As a drawing tool I use mainly Rectangles. I have not deleted the Rectangles for a long time now (more tham 30 days). When I started SC this morning, the system was very very slow. I mean really slow. I have now deleted all Non Text Drawings and now it seems that the system is running normally again. It seems that the drawing tools (rectangles) slow down the system. Am I correct and if so, how should I deal with this in the future. Many thanks |
[2021-03-06 07:25:06] |
Make sure the rectangle drawings do not use any amount of transparency. So the transparency should be 0%. Or 100%.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-06 07:25:12
[2021-03-06 07:40:34] |
Currently they vary between 20% and 80%. The reason for this is that I see, for example, all the rectangles from M60 and M15 in M3, plus those drawn in M3. So far I have always controlled it through the transparency to better distinguish the "sources". I suppose I'll have to recolor the fill colors now. Many thanks |
