Date/Time: Sat, 18 May 2024 18:05:27 +0000
Routing issues AMP
View Count: 469
[2021-03-05 21:57:00] |
mrseho - Posts: 25 |
Hi, I am with AMP. I read that you are working on your Sierra routing solution, which should replace the denali routing issue. With AMP I would have to use CQG for the routing now. I wanted to check in if you had a time line by when you would come out with your sierra solution. It would be great if you could give your timing. Thx, Sebastian
[2021-03-08 17:37:52] |
Refer to: Now Released: Upcoming CME Direct Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
