Date/Time: Sat, 18 May 2024 15:56:20 +0000
1 Stop - 5 Targets
View Count: 998
[2021-03-05 15:22:39] |
User969241 - Posts: 76 |
I am trying to add 1 stop order with a quantity of 5 and then 5 separate targets. I want to be able to 'remove attached stops' so I can move my stop all together and then separate it. I was able to add the 'remove attached stops' to my shortcut menu but when I have 5 separate targets, it makes me add the quantity of 5 to one of the targets to match the stop quantity 5. I am trying to have it as 5 x 1 unit targets and a single 5 unit stop so I can separate the stop when I choose in the trade. How do I set up the target:stops to match quantity?
[2021-03-05 16:39:17] |
bradh - Posts: 859 |
1. Create 5 targets, and 5 stops, then remove the last 4 stops. 2. Select Stop 1 3. In the Group drop-down box select All OCO Groups, and Stop 1 will become Stop All. |
[2021-03-05 17:38:09] |
When I select STOP 1 and then try to select ALL OCO Groups it reverts back to OCO Group 1. It won't let me leave it on ALL OCO Groups.
[2021-03-06 16:58:25] |
If you want to use All OCO Groups you can only have 1 Stop Attached Order. Remove all the others. I want to be able to 'remove attached stops' so I can move my stop all together and then separate it. Regarding this, refer to:Order Types: Remove Link Between Stop Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-06 17:01:10
