Date/Time: Tue, 07 May 2024 01:01:52 +0000
ZSK4 chart issue on Rithmic
View Count: 878
[2014-02-28 15:01:32] |
User50323 - Posts: 7 |
Morning- ZSK4 doesn't seem to be displaying correctly on charts. ZSN4 is fine (and so are other agriculturals). Please see the attached screenshots. Thanks! |
problem Sierra ZSK4.jpg / V - Attached On 2014-02-28 15:00:17 UTC - Size: 435.8 KB - 321 views problem Sierra ZSN4.jpg / V - Attached On 2014-02-28 15:00:34 UTC - Size: 429.78 KB - 381 views |
[2014-02-28 18:46:59] |
What you are presenting is a problem with missing historical Intraday data. The relevant help topic for this is help topic 7: Http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
