Date/Time: Mon, 29 Apr 2024 10:38:31 +0000
Support new lines in DRAWSTYLE_TRANSPARENT_TEXT
View Count: 1093
[2021-03-04 12:35:35] |
User79074 - Posts: 105 |
For DRAWSTYLE_TRANSPARENT_TEXT, can you add support for new lines please. For example "This\nText\nHere" would show This Text Here When drawn. It would be really great. Thanks. |
[2021-04-07 14:29:51] |
Any help here? Multi lines are supported as tool objects. Would like to support them in DRAWSTYLE_TRANSPARENT_TEXT, as that is much faster drawing them and uses less resources than tool objects.
[2021-04-27 07:40:56] |
Please just implement this. It's not that difficult from a programming perspective. I am a programmer and I would know.
[2021-04-28 01:13:13] |
Yes we should be able to have this out in a few days.
[2021-06-23 12:17:01] |
Has this been implemented?
[2021-06-24 07:45:22] |
It has been two months and you said this will be out "in a few days". Can't you respond about this? Or have you dropped the ball?
[2021-06-25 07:42:15] |
Sierra_Chart Engineering - Posts: 14126 |
It was already completed within 5 days of 2021-04-27. Make sure you are running the lastest version of Sierra Chart. We will provide further details. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-25 08:55:38
[2021-06-26 08:24:37] |
Thank you, it works
[2021-06-27 06:23:12] |
Actually, it doesn't work completely. You guys took the short cut. For example If I do this X.TextDrawStyleText = "AAA\n\n\n\n"; Then AAA gets pushed up with blank lines below it. This is correct However this doesn't work properly X.TextDrawStyleText = "\n\n\n\nAAA"; In this case AAA does not get pushed down and there are no blank lines above it.... The newlines are totally ignored here. Please fix this. I know you guys have lots to do, but this should have been implemented properly so that newlines are not ignored if they happen before the text. Date Time Of Last Edit: 2021-06-27 06:23:48
[2021-06-29 19:03:02] |
Please address this, don't ignore it. I really need this feature. On all other platforms new lines are not ignored. This should be a 5 min fix for you guys.
[2021-06-30 12:11:09] |
I really need this implemented properly to complete my coding for a customer, who is getting impatient. thanks.
Date Time Of Last Edit: 2021-06-30 12:11:55
