Date/Time: Mon, 29 Apr 2024 03:16:58 +0000
how to restore a chart menu header?
View Count: 783
[2021-03-04 12:18:32] |
User61576 - Posts: 418 |
I have a chart that looks like this how do I have its menu/header return? |
Screenshot_2.jpg / V - Attached On 2021-03-04 12:18:22 UTC - Size: 13.37 KB - 251 views |
[2021-03-04 16:14:34] |
Assuming this is a Detached chart, you would Right-Click in the area where the text is shown and you will see an option for "Show Menu". Select that to show the menu options, then you can select Chart >> Show Title Bar if you need the title bar. Refer to the following: Chart Menu: Show Menu (Chart menu) If the window is still attached, but not maximized, then you would need to select the options from the Chart pulldown on the main Sierra Chart window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
