Date/Time: Tue, 30 Apr 2024 01:37:21 +0000
Dialog Box positioning
View Count: 384
[2021-03-04 09:15:37] |
User912279 - Posts: 102 |
Hello Sirs, I am using Sierrachart stretched over multiple Windows successfully. My only drag is that the usual Dialog Box, i.e. Study (F6), Settings (F6), Loading (Ctrl+B) and so on, appear always at a very inconvenient place in the upper corner of a screen that I cover with an important App. Could there be a way to set 1) on which part of the screen, or 2) on which screen such a Dialog Box appears? Thank you for your help. |
[2021-03-04 11:00:59] |
This is being worked on.
