Date/Time: Wed, 01 May 2024 08:12:38 +0000
ask-bid grid
View Count: 1584
[2014-02-28 14:09:01] |
User41599 - Posts: 6 |
hi,i'd like to put the ask-bid grid on the chart but i can't find the function, can you help me?
[2014-02-28 17:42:16] |
MotoMoto - Posts: 47 |
do you mean the bid ask lines on a chart? Under Chart Settings>>Show Bid ask lines. http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html |
[2014-02-28 19:30:16] |
Refer to: http://www.sierrachart.com/index.php?l=doc/doc_TradeMenu.html#DrawDOMGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-03 08:15:12] |
ok thanks, i've putted the ask.bid lines, now the problem is that the lines are flashing, before they're still. I mean they appear and disappear. photo here: http://clip2net.com/s/6W5Axf |
[2014-03-03 08:17:57] |
So you are using DTN IQ Feed?
[2014-03-03 09:12:44] |
yes
