Date/Time: Sun, 28 Apr 2024 20:04:08 +0000
trade window always resets my stops/targets while in the session
View Count: 426
[2021-03-03 17:25:13] |
User675119 - Posts: 13 |
it's already several days that I encounter the same problem. I have a trade window attached to chart with stops/targets in place. During the trading session it resets automatically without exit the platform, and I find myself entering trades with stops/targets that I did not set myself. |
[2021-03-03 18:34:05] |
The only way that should occur is if you are changing the Trade Configuration for that window. Refer to the following: Basic Trading and the Trade Window: Selecting/Using a Trade Window Configuration Or if you have the Trade Window linked to other ones. Refer to the following: Basic Trading and the Trade Window: Trade Window Linking The other thing to keep in mind is that the Trade Configuration can be changed with Keyboard Shortcuts. So make sure there isn't a shortcut setup that you do not know about. Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
