Date/Time: Mon, 29 Apr 2024 23:59:59 +0000
Custom study not displaying
View Count: 586
[2021-03-02 14:49:35] |
User202883 - Posts: 24 |
I have a DLL custom study file that is not showing when I go to add custom studies. I've read that I need to recompile it but it seems Build custom studies requires a CPP file and I don't have one, I only have the DLL. What can be done?
[2021-03-02 16:35:55] |
John - SC Support - Posts: 31189 |
You would need to have the CPP file to rebuild. Without it, there is nothing that can be done. Can you get the CPP file from whomever provided you with the original DLL?
[2021-03-02 18:17:07] |
Unfortunately I was not given a CPP file with my purchase of the indicator, just a DLL. Guess that's money down the drain.
[2021-03-02 18:47:48] |
Can you contact that same developer and ask them to give you an updated version? Or see if they still have the source code and are willing to give it to you?
[2021-03-02 20:31:00] |
I can certainly try! Thanks.
[2021-03-02 23:25:38] |
Unfortunately I was not given a CPP file with my purchase of the indicator, just a DLL. Guess that's money down the drain. Definitely contact them and have them just rebuild the study for you even if they do not want to share the source code.This should not be a problem. It is simple and it takes a minute to recompile. Instructions: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-02 23:25:57
