Date/Time: Sat, 12 Jul 2025 00:46:45 +0000
Use of s_UseTool::FontSize with drawing types different than DrawingType::DRAWING_TEXT
View Count: 609
[2021-03-02 07:11:30] |
BrMa - Posts: 80 |
Dear ladies and gentlemen, I'm using ACSIL to draw types of DrawingType::DRAWING_HORIZONTAL_RAY and DrawingType::DRAWING_VERTICALLINE. I am already using s_UseTool::Text to print additional information for these types of drawings... I'd like to change the font size the additional information is displayed with but s_UseTool::FontSize seems to work with DrawingType::DRAWING_TEXT only... would it be possible to adapt the drawing functionality in a way that UseTool::FontSize can be used with other drawing-types as well? Thanks a lot in advance! EDIT: further testing showed that s_UseTool::FontSize and s_UseTool::FontBold works fine with DrawingType::DRAWING_VERTICALLINE but not with DrawingType::DRAWING_HORIZONTAL_RAY - could you please take a look into this if this can be implemented there as well? Date Time Of Last Edit: 2021-03-02 17:01:58
